سعود له
2020-12-18 01:10
Have you ever encountered a situation where the car doesn't move in D gear, and you have to shift to 1st or 2nd gear to start moving?
فهد يحيى
فهد يحيى2021-01-18 11:00
It might be insufficient fuel supply, which usually happens in winter. Just shift gears a few times and it should be fine.
فهد تامر
فهد تامر2020-12-18 02:36
This situation is quite rare. It might be an issue with the shifting logic of your transmission. You may want to have the transmission software checked and updated.
What viscosity of engine oil do you use for your new Mazda5? What's your fuel consumption? And does your transmission shift from 1st to 2nd or 2nd to 3rd gear smoothly? I'm experiencing some jerking.
Is the strong jerkiness when shifting from 1st gear to 2nd in your GA8 a common issue, or is there a problem with the car?
Have you ever encountered an issue where the car shifts from P to N?
Hey folks, my 2017 Haval H2 manual is jerky between 1st and 2nd gear. It feels really tough to shift gears. What's going on here?
Is there anyone who has experienced this situation? When shifting from 1st to 2nd gear, the car doesn't accelerate even though the RPM goes up. I have to release the accelerator and then press it again to make it work. What's going on here? Is it a transmission issue or something else? How did you guys solve it?
My One suddenly won't move when I press the gas while in D gear today. It feels like something is dragging it. Any fellow car enthusiasts know or have encountered this situation before?
Do any of you fellow car enthusiasts feel that the 1st and 2nd gears are noticeably jerky?
Does the S gear shift up and down? Why can it only be in 1st gear and not in 2nd, 3rd, or 4th gear?
Hey fellow car enthusiasts, do all fuel-powered cars experience jerking when shifting gears? Mine does when shifting from 1st to 2nd. In this situation, will the dealership replace the electro-hydraulic module?
Has anyone encountered an issue with a 2017 Skoda Octavia where the gear doesn't shift up when accelerating, or it drops from D3 to D but doesn't move when accelerating? Any advice on how to fix this?
