My BJ40 has run 160,000 kilometers and started burning oil. What should I do?
I bought a used Liana and it's burning oil. What should I do?
I've driven 80,000 kilometers. Do I need to change the transmission oil? Which brand of oil should I use?
The oil light came on while driving the 2012 XV at high speed. I went to the repair shop, and they said it's burning oil. What should I do?
4I bought an '09 Accent and it's burning oil. What should I do? At 80 mph, the RPM is over 2000, and when I accelerate more, it vibrates a bit. Is there a problem? Can it go on the highway?
5Hello MDX car owners, how many liters of engine oil do you usually add during maintenance? How many kilometers can you run? I used Mobil this year, added 5 liters each time, but the oil is almost running out after just over 5000 kilometers. It's burning quite a bit, is this normal?
6How should I deal with my Kia Sportage burning oil after 120,000 km? Does it need a major repair? Has anyone else experienced this? Can you share your thoughts?
7What maintenance should be done at 100,000 kilometers? Do the transmission oil and gear oil need to be replaced?
8What should I pay attention to for the second maintenance of the VS7? Any tips from experienced drivers? Do I need to use fully synthetic oil? Currently, it has run 9,200 kilometers.
9My engine has cylinder scoring after 9 years, what should I do?
10What type of engine oil should I add to my Prado 2700 that has run over 180,000 kilometers but doesn't burn oil? Thank you, everyone!
