حسين رضوان
2024-11-30 01:37
Are BAIC's airbags all this expensive? Does the Urban Hunter top model only have 6 airbags? Aren't airbags supposed to be the most basic safety feature?
عبدالرحمن زكريا
عبدالرحمن زكريا2024-11-30 18:11
I had to buy the Supreme version just for the extra airbags. [I need some quiet] [I need some quiet]
Maintenance guide for the 2007 Opel Astra: 1. **Regular Oil Changes**: Ensure you change the engine oil and oil filter every 5,000 to 7,500 miles to keep the engine running smoothly. 2. **Brake System Check**: Inspect brake pads and discs regularly, approximately every 10,000 miles, and replace them as needed to ensure safety. 3. **Tire Maintenance**: Check tire pressure monthly and rotate tires every 6,000 to 8,000 miles to ensure even wear and prolong tire life. 4. **Air Filter Replacement**: Replace the air filter every 15,000 to 30,000 miles to maintain optimal engine performance. 5. **Coolant Level**: Check and top off the coolant level regularly to prevent the engine from overheating. 6. **Battery Check**: Ensure the battery terminals are clean and the battery is functioning properly, especially before winter. 7. **Transmission Fluid**: Inspect and, if necessary, replace the transmission fluid every 30,000 to 60,000 miles to ensure smooth gear shifts. 8. **Spark Plugs**: Replace spark plugs every 30,000 miles to maintain fuel efficiency and engine performance. 9. **Suspension and Steering**: Regularly inspect the suspension and steering components to ensure a comfortable and safe ride. By adhering to this maintenance schedule, you can help ensure your 2007 Opel Astra continues to perform reliably.
With a budget of 140,000, I'm considering buying a used 7-seater MPV. I'm currently looking at the 2018 imported Volkswagen Sharan and the 2015 Honda Elysion Luxury Edition. I drive about 10,000 kilometers a year. Which one should I choose? The Sharan is newer, has good safety features, and strong power, but maintenance and repairs are expensive, and it requires 95-octane fuel. The Elysion is older, but can run on 92-octane fuel, has lower maintenance costs, is more common, and retains its value well.
For the 2023 Model X, there are several accessories you can consider to enhance practicality beyond the basic seat covers and floor mats, especially for your 5-seater version. Here are some suggestions: 1. **Trunk Organizer**: Helps keep your trunk tidy and maximizes space usage. 2. **Sunshade**: Protects the interior from heat and UV rays, keeping the cabin cool. 3. **Screen Protector**: Prevents scratches and reduces glare on the touchscreen. 4. **Wireless Phone Charger**: Convenient for charging your phone without cables. 5. **All-Weather Floor Liners**: Offer better protection against dirt and spills. 6. **Roof Rack**: Adds extra storage capacity for trips and outdoor activities. 7. **Console Wraps**: Personalizes the interior and protects from scratches. 8. **Portable Vacuum Cleaner**: Keeps the interior clean, especially useful for families or pets. These accessories can improve the functionality and comfort of your Model X.
Congratulations on getting your benefits! If you're planning to get a Cullinan but are new to driving, here are a few tips for beginners: 1. **Take Driving Lessons**: Consider enrolling in a driving school to get professional training. 2. **Understand the Vehicle**: Familiarize yourself with the features and controls of the Cullinan. It's a high-end car with advanced technology. 3. **Start Slow**: Begin practicing in less busy areas to build your confidence. 4. **Safety First**: Always wear your seatbelt and follow traffic rules. 5. **Get Comfortable**: Adjust your seat and mirrors before driving to ensure you're comfortable and have good visibility. 6. **Parking Practice**: Spend time practicing parking, as it can be challenging for new drivers. Once you're confident with these basics, driving your new Cullinan will be an enjoyable experience!
If you're looking for an SUV around 130,000 RMB for daily family use, Chery Tiggo 8, Jetour X90, and Haval Big Dog are all decent options. Here's a brief overview to help you decide: 1. **Chery Tiggo 8**: Known for its spacious interior and good value for money. It's a solid choice if you prioritize comfort and practicality. 2. **Jetour X90**: Offers a roomy cabin with flexible seating arrangements, making it great for family trips. It's also equipped with a range of features for convenience. 3. **Haval Big Dog**: Stands out with its unique design and off-road capabilities. If you enjoy a rugged look and some adventure, this might be the one for you. Consider what features are most important for your daily needs, like interior space, tech features, or off-road capabilities, to make the best choice.
Choosing between the Volkswagen T-Roc and the Mazda CX-30 can be tough, especially when both second-to-top trims are appealing. Here are some points to consider: 1. **Performance and Handling**: Check which car offers the driving experience you prefer. Volkswagen is often praised for its solid performance, while Mazda is known for its sporty handling. 2. **Interior and Comfort**: Look at the interior quality and comfort. Volkswagen might offer a more classic design, whereas Mazda often has a more stylish and modern interior. 3. **Features and Technology**: Compare the features and tech offered in each model. Consider what’s important to you, like infotainment systems or safety features. 4. **Fuel Economy**: Consider the Fuel economy of each model if that's a priority for you. 5. **Brand Preference and Resale Value**: Sometimes, brand loyalty or resale value might influence your decision. Ultimately, it depends on your personal preferences and priorities. Test driving both might help you decide!
If you're considering buying an RDX, it's generally recommended to look for models from recent years as they tend to have the latest safety features and technology. When choosing between a two-wheel drive (2WD) top trim and a four-wheel drive (4WD), it depends on your driving conditions. If you're mostly driving on highways and in urban areas, a 2WD might be sufficient and could offer better fuel economy. However, if you want extra traction and stability, especially in adverse weather conditions, a 4WD would be a safer option. In terms of safety, newer models typically have more advanced safety technologies. Always check the specific safety features available in the model year you're considering.
Choosing between the G80 and the XFL depends on your personal preferences and needs. Here are some things to consider: 1. **Brand and Model**: - G80 generally refers to the Genesis G80, a luxury sedan known for its comfort and advanced technology. - XFL typically refers to the Jaguar XFL, which is the long-wheelbase version of the Jaguar XF, offering more rear-seat space and luxury features. 2. **Performance**: - Consider the engine options and horsepower each model offers. The G80 might offer a more powerful engine, while the XFL might focus on a balanced ride. 3. **Features**: - Look at the features each car offers, like the infotainment system, loudspeakers, safety features, and interior quality. The G80 is known for its tech-savvy features, while the XFL may emphasize luxury and style. 4. **Fuel Economy**: - Check the fuel economy for both. If fuel efficiency is a priority, this might influence your decision. 5. **Comfort and Space**: - If rear-seat space is important, the XFL might have the edge due to its extended wheelbase. 6. **Budget**: - Consider the price and what fits better within your budget, including maintenance costs. Ultimately, test driving both and considering these factors could help make your decision easier.
For your first time driving a 09 Mazda 6, here are some things you might want to consider: 1. **Basic Checks:** Before you start driving, check the fuel level, tire pressure, and ensure all the lights are functioning properly. 2. **Maintenance History:** If possible, review the car’s maintenance history to ensure it's up to date with regular services. 3. **Test Drive:** Take the car for a short drive to see if there are any unusual noises or vibrations. 4. **Visit a Mechanic:** If you're unsure about the car's condition, it might be a good idea to visit a mechanic for a thorough check-up. 5. **Familiarize Yourself:** Get comfortable with the car's controls, like the brakes, accelerator, and steering. Remember, safety first!
BAIC BAIC BJ40
BAIC BJ40AED 129,000Gasoline
