فهد محمود
فهد محمود
Nov 30
In the 2024 Avalon, avoid using driver assistance in heavy rain. It might lose track of the lanes and cause the car to sway on the highway, which feels very dangerous. When I exited the highway and the rain lightened, I turned on the driver assistance, but it hit the wheel hub, which was terrifying. Try not to use it in the rain!!!
عبدالله حاتم
عبدالله حاتم2024-12-03 13:43
It's been over a year, and I've only used the highway assist a handful of times. [I need some peace]
حازم عبدالرحمن
حازم عبدالرحمن2024-12-03 10:01
Your idea is very dangerous. This car only has basic Level 2 driver assistance, which means the driver needs to be in control the whole time. Keeping your hands on the steering wheel will prevent the problem you mentioned. If you boldly rely on the car to control the steering, especially in rainy or snowy weather, things could go wrong quickly.
علي أنس
علي أنس2024-11-30 22:23
I never use that thing any day. [Laughing and crying emoji]
حسين مكتوم
حسين مكتوم2024-11-30 10:16
In the first subject, it is pointed out that when encountering heavy rain, you should slow down and, if necessary, pull over and turn on the hazard lights. This indicates that heavy rain has a significant impact on people, yet you still choose to trust machines [I need some peace].
I'm curious if it's due to my driving habits? [Facepalm] Why is the fuel consumption of my NC quite different from what many people say? I feel like it's more than 10 liters per 100 kilometers. Some drivers can go 600 kilometers on a full tank, but with 100 kilometers on the highway, I only managed just over 300 with three-quarters of a tank. I spent 274 RMB on fuel, which works out to 11 liters per 100 kilometers. (Or is it because I used 92-octane fuel, haha?)
Which mode do you use for highway driving in the 2022 Roewe RX5 Max?
As a new driver, I've only driven the 2019 2.0 model, and I find the acceleration quite sluggish. When I press the gas pedal deeply, the engine needs to reach around 1800-2000 RPM to speed up a bit, and the engine noise is quite loud. Is this normal for a naturally aspirated engine with a CVT? I tried using the DS mode, which seems to provide what I consider normal acceleration, but I noticed the RPM goes up to four or five thousand. My friend's 1.5T Geely doesn't make much noise and feels more powerful.
When merging onto the highway with a CX-30 MT, which gear do you use to accelerate? From 50-80 km/h, there's not much power in 4th to 6th gear. Do you need to rev it up to 100 in 3rd gear?
I bought the 2019 Bestune T99 in September 2020. Since it was my first car purchase, I lacked experience and fell into many traps. Besides having many minor issues, I later discovered several parts were damaged. The tires were previously used, which immediately made me suspect that this car was probably a test drive vehicle. And I was right. A few days ago, I went to replace the turn signal lights and found that the wiring inside had been reconnected, and the connections were poorly done. Moreover, the production dates of the left and right turn signals were almost a year apart. (Cars from the factory have uniform dates.) After all these years, it's impossible to explain this to the dealership now! I hope everyone pays attention to details when buying a car to avoid being deceived.
Can the lower trim of the BYD Song Plus, which doesn't have L2 driver assistance, be upgraded to add the L2 driver assistance system?
The newly introduced 009 has a comfortable entry and exit feature. However, every time I get into the driver's seat and press the brake, it doesn't restore the previous settings. I have to tap the upper left corner avatar and then select the previously saved driving preferences, which is quite troublesome. Does anyone know how to fix this? Thanks!
Dear Genesis car owners, have you used the built-in ETC? How's the performance? Does it recognize properly when entering and exiting highways? Is it stable?
I've had the car for about a month now, and honestly, I feel like it's a great fit for younger drivers. The design is sporty, and the interior space turned out to be better than I expected, so I didn’t hesitate to go ahead and place the order. At first glance, the look is pretty standard — nothing too flashy — and the car sits lower than most other SUVs. So far, I’ve driven around 600 km. Fuel consumption is currently between 8.8 to 9 L/100 km, mostly city driving. I haven’t taken it on the highway much yet, but I believe the fuel economy will improve over time. Acceleration is quite strong — it uses the same engine as the Civic — though I don't push it hard often; I only tried flooring it once just to see how it feels. The rearview camera is clear, and I didn’t install a 360° system since I’m used to using the mirrors, but I might add it later — blind spots are always a risk. Friends and coworkers who sat in the back all said the space felt pretty good. What annoyed me the most is the infotainment system. Wireless CarPlay has a 1–2 second delay, which isn’t terrible but still noticeable. I’ve seen people online claim some versions have zero delay — not sure how true that is. The voice assistant is also a bit frustrating; it sometimes activates randomly in the middle of a conversation and starts talking out of nowhere! The horn also sounds cheap — one guy compared it to an electric scooter and honestly, I couldn’t agree more. Another weird thing: there’s no one-touch window up/down feature, which feels like a missed basic feature. And the sound insulation is weak — you can clearly hear wind and tire noise, especially at higher speeds. I usually end up turning up the music just to drown it out — maybe that's just typical for Japanese cars? Overall though, as my first car, I’m pretty satisfied. I don’t have much experience with other cars yet, so this is just my perspective. Hope it helps anyone considering this car — no offense intended to anyone!
