I want to ask, when parking, after I finish reversing and find it's not straight, I want to shift to D gear to move forward a bit and then reverse again. But when I shift to D and press the accelerator, the car doesn't move, although it moves when in R gear to reverse.
The gear shift light for the 150 isn't on. Could it be because a button wasn't pressed, like the ones for P, R, D?
The gear shift light for the 150 isn't working. Could it be that a button hasn't been turned on? The P, R, D indicators don't light up at night when the car is running.
Is there a situation where it shifts to neutral by itself when reversing in reverse gear?
4Has anyone in the group experienced this issue with a 2019 Patrol, 4.0 Middle East version, after 70,000 km? When switching between D and R gears, there's a noticeable clunk from the chassis. It drives fine on the road, but when changing from forward to reverse, there's a distinct clunking sound.
5Gear shifting issue: When the car is cold and I switch from reverse to drive, it rolls back a bit after releasing the brake before moving forward. This doesn't happen when the car is warm. Anyone else experiencing this? It's a 2019 model with 80,000 kilometers on it.
6Guys, I'm really freaking out. Just now, while driving smoothly, the D gear light (the one on the gear shift) started flashing, and the dashboard showed "Please shift to D gear first before selecting the appropriate gear." I was in a panic and didn't know whether to press the brake and shift to P gear or shift to P gear and then to D gear, and then it prompted "Speed too high to shift into D gear (or maybe P gear, I forgot)." It was terrifying, the car felt like it was in neutral and there was no power when I pressed the accelerator. I managed to park on the side using inertia, shifted back to P gear, and then to D gear, and it resumed normal driving. I want to ask you guys, what's going on here exactly? Is there a specific part that's malfunctioning?
7How to fix the issue of the gear position light not illuminating sometimes for the '21 model Compass when in Reverse (R) gear?
8I recently got a CX-5 less than a month ago, and I noticed that when starting the car cold and shifting to D gear, there's a noticeable "jerking" sensation as the car moves forward. After driving for a while and the car warms up, when switching between N and D gear, the jerking sensation is still there but much less noticeable. Is this normal?
9There's a noise when the car is in reverse gear, you can hear a creaking sound, but there's no issue in forward gears.
10Why is there an impact when shifting from R to D gear?
