علي شجاع
Sep 12
What should I do if my 2010 Opel Astra GTC 1.8L has a cylinder misfire?
علي شجاع2020-09-12 10:49
Where can I find parts for Opel Astra? It's really hard to find them on the market.
عبد العزيز هكيل2020-09-12 10:33
When the engine of the vehicle is misfiring, it's mostly due to issues with the original spark plugs or the ignition coil. We need to visit the service center to check the spark plugs and ignition coil.
عبدالرحمن باهر2020-09-12 10:23
If the engine is experiencing misfire, you should use a diagnostic computer to first check the engine misfire data. Identify which cylinder is misfiring, and then replacing the spark plug or ignition coil can solve the issue.
What should I do if I can't get my hand under the hood?
What should I do if I lose my car key?
4What should I do if the trunk of my 1.6 automatic car has water ingress? Is it a big issue?
5What should I do if the brakes on my Maxus T60 feel soft?
6My navigation card is lost, what should I do?
7What should I do if my car battery is dead?
8What should I do if there's an airbag fault in my Touareg?
9What should I do if I don't use my car for a long time?
10My engine has cylinder scoring after 9 years, what should I do?
