خالد رومي
2024-10-09 21:12
Why does the windshield washer fluid in my 2024 Arrizo 5 run out after just spraying three to five times? I've refilled it three times in a month and used it only about 10 times in total, each time just 1-2 sprays. Could the bottle be leaking? 😂😂😂
خالد رومي
خالد رومي2024-10-21 12:42
Thank you, bro, for taking the time to answer. 🌹
فهد نوري
فهد نوري2024-10-11 16:24
Open the hood and take a look. It's not possible for it to be used up this quickly.
محمد مدرسي
محمد مدرسي2024-10-11 08:16
Check for leaks yourself.
I've had my eye on this car for a long time. Over the years, I've been collecting scrap books, newspapers, steel bars, glass bottles, cans, and various plastic bottles. Now I'm just 20 kilos of bottles short. Can any brother help me out? Once I get the car, I'll return the favor!
The windshield washer spray on the Rapid is too coarse and too low, spraying below the wipers. How can I adjust it to be finer and higher?
Which button on the Ghibli can spray the windshield washer fluid? I've tried the wipers, they work, but I don't know how to spray the fluid. Can any fellow car enthusiasts tell me? Thanks!
BYD Song Plus 2.0 Fuel version, the windshield washer fluid doesn't spray out, but after driving for a while, it starts working again. What could be the problem?
I have a couple of minor issues with my Touareg 3.0, wondering if anyone else has experienced the same: 1) After refilling the windshield washer fluid, it leaks onto the ground. The mechanic suggested that it might be a crack in the connecting hose, causing the fluid to spill out. It doesn't affect usage. 2) Occasionally, when driving at low speeds in traffic, there's a slight squeaking sound when turning the steering wheel. It doesn't happen all the time and doesn't seem to have much impact.
The windshield washer isn't spraying water, even though the tank is full. Does anyone know what's going on? Do I need to go to the 4S shop to fix it?
What could cause the 2014 Peugeot 308 to not spray windshield washer fluid? Is it the lever on the right side of the steering wheel that needs to be lifted forward for a few seconds? I can't find the spray nozzles, so I'm considering using a needle to check if they're clogged. Any advice from the experts?
Peugeot 3008 windscreen washer not working? I've already added three bottles of fluid.
Chery Chery Arrizo 5
Chery Arrizo 5AED 35,795 ~ 38,000Gasoline
