عبدالله ناصر
2024-10-11 08:28
The steering wheel is crooked 🤦‍♂️. Even after doing a wheel alignment, it can't be fixed. The mechanic said it's caused by a deformed lower control arm?
عبد العزيز كمال
عبد العزيز كمال2024-10-22 21:28
Steering wheel pulling to the left is a common issue.
عبدالرحمن عبد القادر
عبدالرحمن عبد القادر2024-10-21 15:31
The timing belt is loose, have the 4S shop adjust it. If it's not serious, it should be fine.
نايف طاهر
نايف طاهر2024-10-16 12:59
That's how it comes from the factory, don't bother.
Hey guys, my Land Cruiser tends to pull the steering wheel when driving on bumpy roads, and it doesn't feel very stable. I've already done a wheel alignment, and the mechanic said there's nothing wrong. Is the steering wheel pulling a normal phenomenon?
Requirements for the front lower control arm.
It could be due to several reasons such as engine misfire, idle air control valve issues, or even problems with the transmission mounts. It's best to have a mechanic check it out to diagnose the exact cause.
How many control arms are there on the right rear suspension of the 2018 Hongqi H7 if the control arm and lower arm are bent?
Did the mechanic place the jack on the edge of the bodywork when your tire was punctured, causing it to deform? Has this happened to you as well?
What should I do if the half shaft of my 2009 Jetta is worn out? The subframe and lower control arm were just replaced.
My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
Chery Chery Arrizo 5
Chery Arrizo 5AED 35,795 ~ 38,000Gasoline
