عبد العزيز مروان
2022-12-12 10:53
The maintenance manual for the Arrizo 5 suggests adding 4.7L of engine oil, but most services on the market typically charge based on 4L. Has anyone tried only adding 4L?
Comments( 6 )
جواد سلمان
جواد سلمان2024-11-28 08:36
I always add 4 liters, been doing this for 7 years, no issues. The oil dipstick shows slightly below the middle, but I don't drive much.
حسن نور الله
حسن نور الله2022-12-17 19:14
Are your cars manual or automatic?
محمد مكي
محمد مكي2022-12-16 13:40
Buying the international version of Mobil 1 full synthetic on JD International costs less than 200 yuan per bottle. Each bottle is 5 pints, which is equivalent to 4.73 liters. You’ll still have a little left over after each refill.
سلمان هشام
سلمان هشام2022-12-13 12:11
I bought a 3.5kg bottle at a Sinopec gas station, which converts to 4L. Adding it in can also reach the gauge range.
سعود مروان
سعود مروان2022-12-13 09:39
My setup is the same as the guy upstairs, a 4+1 combo. In reality, refueling is around 4.5-4.7, and there's usually some left over that can't be used.
فهد هشام
فهد هشام2022-12-12 13:28
I now add oil using a 4+1 method, one 4-liter bottle and one 1-liter bottle. Adding just a 4-liter one is fine, but since I often drive long distances, I stick to 4+1. Previously, the engine light turned on [I want to be alone].
The engine number of the Arrizo 3 is typically located on the engine block itself. You might find it on the side of the engine or near the engine's base. If you're having trouble locating it, I recommend checking the vehicle's manual or contacting a professional mechanic for assistance.
Hey guys with the 301, I'm feeling that the car noise is too loud. I just did maintenance two months ago and also replaced the tires with the original Giti 221. What's going on? The engine hood and trunk lid don't have any soundproof cotton. Would adding some help? Have any of you guys tried it?
Hello MDX car owners, how many liters of engine oil do you usually add during maintenance? How many kilometers can you run? I used Mobil this year, added 5 liters each time, but the oil is almost running out after just over 5000 kilometers. It's burning quite a bit, is this normal?
Yesterday, I went for a car maintenance, and the oil draining took a bit longer. The mechanic said that adding just over 4 liters of oil wasn't enough, so they added a bit more, totaling 5 liters. Is this reasonable?
The timing belt in a Kia Sportage engine typically needs to be replaced every 60,000 to 100,000 kilometers. However, it's always best to check the owner's manual or consult with a professional mechanic for the most accurate maintenance schedule for your specific vehicle model.
I just received the news that the local 4S shop has closed. I want to ask, for car owners without a local 4S shop, how do you handle regular maintenance? Do you have to go to another city for the 15 maintenance services over the 5 years for a new car?
What maintenance is typically needed for a 60,000-kilometer major service?
Yesterday, I went for the three-year warranty and maintenance. The after-sales service suggested I change my tires, saying the treads are almost worn out. I've driven 56,000 kilometers. How many kilometers did everyone else change their tires at? Has anyone switched to different tires? Continental is really too expensive for me. Are there any high cost-performance alternatives?
Chery Chery Arrizo 5
Chery Arrizo 5AED 35,795 ~ 38,000Gasoline
