Is it normal for the rear wheel bearing to fail after 37,000 kilometers?
Is it normal for the T8 to require manual regeneration every ten to twenty days after 10,000 kilometers of driving on low-speed, mountainous roads? After multiple regenerations, it fails and needs to be taken to the 4S shop for computer regeneration, and there's also a significant increase in the oil level. Can fellow car enthusiasts share their experiences?
Is it normal for the steering wheel to shake when driving at 120 km/h on the highway after the car has been driven for 100,000 kilometers?
Has anyone ever replaced the rear wheel bearing on Xiaoya?
4JAC T8 Pro's rear crash beam rusted after just 6000 kilometers 😅
5Do your car's wheel bearings break easily? I just replaced them 3,000 kilometers ago and they're broken again. Is this a common issue with this car model, or could it be caused by something else?
6Is it normal for the rear wheel bearing to fail after 37,000 kilometers?
7Why does the car often fail to unlock or start after changing the battery?
8The original spark plug failed after just over 10,000 kilometers. How about you guys?
9When the car speed is within 20 km/h, there's a squeaking noise from the left rear wheel, and the brake pads are normal.
10Are there any fellow drivers experiencing severe rear tire wear? After 30,000 kilometers, the rear tire treads are down to the warning line...
