خالد دين
2024-11-29 15:19
I have a 2019 Chery Arrizo 5. Recently, the check engine light came on while driving, but it didn't affect the driving performance. I went to a repair shop, and they checked it with a computer and said there was no issue. After restarting the car, the light went off. Today, the check engine light came on again while driving, but it still doesn't affect the driving. Does anyone know what the problem might be?
عبدالرحمن أكرم
عبدالرحمن أكرم2024-12-04 10:20
The positive and negative terminal nuts on the battery weren't tightened, and I experienced the same issue.
سلمان حمد
سلمان حمد2024-11-29 15:34
Take a drive on the highway, rev up the engine, and after a few hours, it should be fine.
Recently, my engine light came on. I went to the shop to reset it, but it came back on, indicating "Please check the emission system." Can any expert advise?
The dashboard reported low transmission performance, and then the car wouldn't accelerate. After restarting, the warning light went off and it drove normally. What could be the reason? (The onboard computer cleared the fault light, but it came back on before I got home.)
After cleaning the throttle body yourself, the engine warning light came on. It doesn't affect driving, but how can you resolve this?
The Check Engine light on my JETOUR X70 with 40,000 kilometers suddenly came on.
The engine warning light came on after driving over 10,000 kilometers, right when it was time for maintenance. The service station checked and found the gas cap wasn't properly sealed, and they reset the computer. However, the yellow light came back on in less than half a month. The service station is too far away, and I don't have time to go there. Does anyone know what the problem might be? Any help would be appreciated.
The EPC light came on twice, but restarting the engine fixed it, and it hasn't appeared again. Fellow car enthusiasts, what could most likely be the issue?
I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
While driving, the central control screen suddenly went black, then restarted after two to three minutes, followed by a "pop" sound. Any ideas?
Chery Chery Arrizo 5
Chery Arrizo 5AED 35,795 ~ 38,000Gasoline
