How many kilometers should you typically change the transmission oil?
Comments( 7 )
How many liters of transmission oil does the GA8 need to change? Should it be by gravity?
For the 2021 Santana Automatic Comfort Edition 1.5L, how many kilometers should it be before changing the transmission oil?
4How is this brand A engine oil? Has anyone used it? How many kilometers do you change it?
5Hey fellow car enthusiasts, at how many kilometers did you change the transmission oil for your RDX?
6Hey car enthusiasts, at how many kilometers did you change the transmission oil for your Territory?
7How often should the transmission oil be changed?
8How many kilometers should you typically change the transmission oil?
9When did you all change your transmission oil, and at how many kilometers?
10For a 2021 Santana Automatic Fashion Edition 1.5L, how many kilometers should you drive before changing the transmission oil?
