نصر عبد العزيز
نصر عبد العزيز
Nov 29
Hello fellow Chery Arrizo 5 manual drivers, I'm a newbie. Sometimes when driving, I get nervous and press the accelerator instead of the brake. My instructor said to press the brake straight and the accelerator at an angle. But sometimes, when I'm nervous, I mistakenly press the accelerator instead of the brake, which is really dangerous. Do you have any good tips? Or am I just not skilled enough yet? I've only had my car for a month and have already pressed the accelerator instead of the brake twice. Do you have any good advice? Please share, okay?
Comments( 13 )
عمر صعب
عمر صعب2024-12-02 21:13
Keep bumping, and you'll get used to it.
نايف كامل
نايف كامل2024-12-02 09:56
Use your heel as a pivot while driving. When you don't need to accelerate, rest your foot on the brake pedal. The more you drive, the more skilled you'll become.
يونس سعود
يونس سعود2024-12-02 00:05
I've been thinking about buying an A5 recently. I've had my driver's license for a few years but haven't driven much. [I want to be alone]
عبد العزيز فخريل دين
عبد العزيز فخريل دين2024-12-01 23:10
Repetitive practice helps form muscle memory.
علي عبد له
علي عبد له2024-12-01 22:50
When you're nervous, just step on the clutch together.
سلمان قنصوح
سلمان قنصوح2024-12-01 13:16
I am also a beginner, and I just silently encourage myself. If others can do it, I can too. There's nothing to be nervous about. I just keep reminding myself of this. I got my driver's license on June 1st last year, but I hadn't driven a car. Recently, I bought a second-hand Arrizo 5 and mustered up the courage to drive it home. A few days ago, I gathered the courage again and drove directly onto the highway.
سلمان علياء
سلمان علياء2024-12-01 07:49
Don't worry, it's just like riding a motorcycle or an electric bike on the road.
زياد عبدالله
زياد عبدالله2024-12-01 06:29
Then you can only drive at noon! [I want to be alone]
سلمان فاروق
سلمان فاروق2024-12-01 06:26
Drive more and you'll get used to it. Just keep your attention focused when driving. Even if you floor the accelerator in this car, the acceleration is really slow, giving you plenty of time to react.
سعود سا مرعي
سعود سا مرعي2024-12-01 03:59
Don't start the engine! Practice more in the cabin! Use mental cues! You'll get better with practice. 👌
When I press the accelerator while the car is stationary, it jerks like a newbie driving a manual car. But if I let it coast a bit after releasing the brake and then press the accelerator, it runs smoothly. Does anyone know what might be causing this? ╮(╯_╰)╭
Does this car have good braking performance?
When the 2006 Legacy is in drive and you press the brake, there's a "doo doo" noise from the chassis, and the steering wheel and brake pedal vibrate. Sometimes it's mild, sometimes strong, and sometimes there's no issue at all. Could it be because the brake silencer pads weren't installed properly?
Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
Is it normal for the brakes to apply themselves without pressing the accelerator while driving?
Hey drivers, anyone know why my car suddenly can't accelerate while driving? I press the gas pedal and nothing happens. 😩😩 Then, when I press the brake and then the gas pedal, it accelerates. What's going on? 😎
When driving, sometimes when I press the accelerator, I feel a jerk, like there's suddenly no power, and then it's fine again. What's going on? Does anyone else have the same issue?
I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
Will the 2024 JETOUR X90 PLUS automatically release the electronic parking brake when the accelerator is pressed during start-up?
Chery Arrizo 5
Chery Arrizo 5AED 35,795 ~ 399,000Gasoline
