نايف يعقوبي
2024-12-04 07:00
Does it really take four to five minutes to warm up before you can start driving the Arrizo 5?
ضياء فهد
ضياء فهد2024-12-04 09:12
Just drive normally, and you'll be fine as long as you don't floor the accelerator.
محمد إبراهيم
محمد إبراهيم2024-12-04 09:11
No, the engine warms up very slowly when stationary. Driving at low speeds during warm-up will be faster, just make sure not to drive aggressively.
Fellow car enthusiasts, does your car take a long time to heat up? It seems like I need to drive 8 or 9 kilometers before the water temperature is sufficient, otherwise I'm hesitant to turn on the heater. If the car is warmed up for a while, it's a bit better. Do you guys have any solutions? 🙏🙏
Is it normal for the Jeep Wrangler to have strong jerking sensations when starting right after warming up?
When the car starts, the ESP warning and engine fault warning appear, and it can't shift gears. It needs to warm up for half an hour before it can move. How can I solve this?
Hello fellow car enthusiasts, have any of you cleaned the throttle body before? I've heard that cleaning the throttle body on an MG3 is quite a hassle, taking up to 5 hours and costing 500 bucks.
Is it normal for the 2021 four-wheel drive to show an icon on the dashboard with the front wheels tilted, or is it a four-wheel drive warning? The dealer says it's normal, but it didn't seem to be there before. 🤦‍♂️
Why is my car often sluggish when starting, as if it takes a long time to start up?
The engine takes 5 minutes to idle down after warming up. What could be the problem?
Are there no two-wheel-drive four-seater options for the 25 models? If I want a five-seater, do I have to choose the four-wheel drive?
I didn't drive for two days, and when I started the car today, I noticed the engine warning light was on. For the first ten minutes or so, pressing the accelerator only increased the RPM, and the speed stayed below 20. After driving for about ten minutes, when I pressed the accelerator, there was a humming noise, and the speed gradually picked up. However, the fuel consumption display kept changing even when the car was parked or just started and not moving (or maybe I hadn't noticed this before). Can anyone advise what's going on? Has anyone experienced this before?
What's the RPM of your 2024 Chery Arrizo 5 manual when driving at 120 km/h on the highway?
Chery Chery Arrizo 5
Chery Arrizo 5AED 35,795 ~ 38,000Gasoline
