عبد العزيز كريم
2020-04-12 19:47
My Chery Arrizo 3 makes a humming noise from the rear when the speed increases. Not sure what's broken.
علي آسيا
علي آسيا2020-04-14 10:02
Where is the noise coming from?
فهد تامر
فهد تامر2020-04-12 19:56
First, check whether the noise is coming from inside or outside. If it's from outside, it could be tire noise or wind noise. If it's from inside, it might be due to some trim panels not being installed properly, causing vibrations.
فارس عبدالرحمن
فارس عبدالرحمن2020-04-12 19:53
If this happens, I personally suggest pressing down on the rear roof area or the trim panel of the C-pillar when you hear the noise. It's possible that there is resonance causing it.
Chery Chery Arrizo 3
Chery Arrizo 3AED 35,000 ~ 38,000Gasoline
