Is the electronic throttle response of your Arrizo 3 slow to return? Can it be adjusted?
The Koleos accelerator pedal feels too soft. Can it be adjusted to be firmer? It's hard for a beginner to control the throttle.
Can the navigation system in the Chery Arrizo 3 be upgraded?
Can a 2015 Arrizo 3 still be bought? The condition is good, and it has run 20,300 kilometers. The asking price is 20,000.
4How can I prevent the Arrizo 3 radio from turning on automatically?
5Can the rear fender of the Arrizo 3 be fitted with an inner liner?
6Is the electronic throttle response of your Arrizo 3 slow to return? Can it be adjusted?
7Is the steering wheel of the third-generation Changan Yuexiang a bit heavy? Is yours like this too? Can it be adjusted?
8You can start by calmly explaining the situation to the 4S shop. Let them know that after your recent maintenance, the coolant return hose wasn't secured properly, leading to damage to the turbocharger and causing the car not to start. Ask them to take responsibility for the mistake and discuss possible solutions, such as repair or compensation. It's important to have any relevant documentation, like your service records, ready to support your case.
9Has anyone driven the Arrizo 8 and the Jetour X90 Plus? Can you share your experience on which one is better to drive? I'm currently trying to decide between the two.
10Does your car's steering wheel automatically return to center when you make slight adjustments at high speeds? When you make minor adjustments with one hand, do you feel a lot of resistance?
