هارون سلمان
2022-02-14 12:30
I'm planning to change cars and don't intend to go with Chery again. I'm considering the second-generation Changan 75p, as I heard it comes standard with an 8-speed automatic transmission (8AT).
خالد ابيض
خالد ابيض2022-07-25 23:15
For household use, there's no need for AT. The most durable CVT can also run 200,000 kilometers. The chances of the transmission breaking down are really small.
عبدالرحمن قنصوح
عبدالرحمن قنصوح2022-03-21 16:24
Are you ready to sell? Where is it located?
Hi everyone, since the Vito Elite 8-seater has a 2-3-3 layout, does the second row have sliding rails? How do you get into the third row? I've been wanting to buy the 8-seater Elite but I'm really worried about the access problem. [Facepalm][Facepalm][Facepalm]
I'm considering buying a Scirocco R. Should I go for the last generation with the EA113 engine or the earlier one with the second-generation EA888 engine?
I'm planning to get the 2018 5.6 Standard model. Guys, let's chat about it! Thanks~
I'm planning to buy a car after the New Year, and I'm undecided between these three models: "Geely Boyue," "Bestune T99," and "Hongqi HS5." I don't know which one to choose!
I changed the transmission oil at 40,000 km at the 4S shop, and now at 100,000 km, I'm planning to replace it for the second time. I'm considering using Shell CVT transmission oil. Has anyone tried it? Is it okay to just clean the metal filter?
Hey everyone. I'm currently looking at the Hongqi HS5, Tiggo 8 Pro, Geely Xingyue L, and the more affordable Jetour X90. Could you guys share your thoughts? Which one should I go for? Also, can Geely and Chery's own AT transmissions be the first choice?
I'm planning to buy the dual-motor version of X. Can you tell me how much the battery might drain if I don't use it for half a month?
Regarding the cost-effectiveness of Jetur X90, Chery Tiggo 8, and Geely, which one is higher? I'm a newbie and don't really understand.
I'm considering getting a used MG6, second generation manual. How is it? Are there any major issues, and is it worth buying? [smile]
Chery Chery Arrizo 3
Chery Arrizo 3AED 35,000 ~ 38,000Gasoline
