عمر يسار
2020-11-29 12:41
Can the navigation system in the Chery Arrizo 3 be upgraded?
محمد خير الدين2020-12-17 19:00
It's not possible, you can only replace the central control screen.
سعود يزيد2020-12-01 09:43
There's no need to upgrade the car's navigation system! Using a smartphone is more flexible; the car's navigation system is completely redundant.
حسين يعقوبي2020-11-29 14:02
You can upgrade the navigation by downloading the map to your memory card, or you can go to the 4S shop and have them upgrade the map for you. Otherwise, if the map version is too old, you might not be able to find certain places.
My Chery Arrizo 3 makes a humming noise from the rear when the speed increases. Not sure what's broken.
How is the Arrizo 3?
4Navigation Issues: Can the car system be upgraded? Or can the navigation maps be updated? If using CarLife for navigation, does it use the phone's GPS, or can it use the car's GPS?
5Is there an Arrizo 3 for sale?
6Can the rear fender of the Arrizo 3 be fitted with an inner liner?
7Is it possible to upgrade the navigation system on the 2017 model since it's outdated?
8Can the car's navigation system sync with the phone?
9Is there a Chery Arrizo 5 1.5L manual version?
10How much is the lowest configuration of the Chery Arrizo 5 manual version?
