سعود منصور
Sep 19
Why do my Ariya tires need to be inflated every week? All four tires are losing air. I inflated them to 270 kPa, but after a week, they're only at 250-260 kPa.
Comments( 10 )
Hello, car enthusiasts group. When swapping the positions of all four tires, is it necessary to do wheel balancing and alignment?
I'm not sure why your tires appear underinflated, especially the front ones, even though all four tires are at 250 kPa.
4How do you inflate the rear dual tires on your Ousheng? The tire shops here have to take them off to inflate them.
5I'm planning to change my tires. Does anyone have cheaper sources for Michelin? I need to replace all four. [Facepalm][Facepalm]
6What tires are you all using? It's been six years, time to change them.
7Does anyone know the size of the air conditioning filter for the 2019 GAC GA6? I've bought many, but they're all a bit thin. I got one from the store before that fit perfectly. This filter is thicker than the usual ones!
8The recommended tire pressure for the old model GS5 is typically around 2.1 bar, so having all four tires at 2.1 should be fine. However, it's always best to check the vehicle's manual or the placard on the driver's side door jamb for the exact specifications.
9I only replaced the front two tires, not the rear ones, and they're from two different brands. The tread patterns are quite different, and the load capacity and speed ratings aren't the same. Is this okay? Is there any risk? Do I need to replace the rear tires as well?
10Why do my Ariya tires need to be inflated every week? All four tires are losing air. I inflated them to 270 kPa, but after a week, they're only at 250-260 kPa.
