نايف خضير
نايف خضير
Oct 1
How to set up the Ariel so that the front passenger or rear passengers can open the door without the driver needing to press the unlock button? Please help!
سلمان إلياس
سلمان إلياس2024-10-01 18:10
Car system settings, unlock in P gear. Once parked and the driver shifts to P gear, all car doors unlock.
Why does my car window go down but not come back up, and I have to press the unlock button repeatedly to open it? [Facepalm]
For the 2012 Honda City, the doors can only be opened after turning off the engine. How can you set it to open the doors without turning off the engine? Also, when the car starts and you press the brake, the doors automatically lock.
Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
My Roewe Max RX5 remote suddenly can't unlock the car doors. Can someone please help me out?
Is there no interior trunk release button on the 2016 Red Badge 1.5T Automatic 2WD Luxury model? Can it only be opened from the trunk door? Anyone who knows, please help 🙏
The trunk door of my X-Trail can't be opened or closed manually (I can hear a click from the manual button, but the door doesn't pop up automatically). However, it can be opened with the key. What could be the issue? Please help, thank you 🙏
Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
The inner button on the passenger door isn't working, but it can be opened using the screen controls and from the outside. What could be the reason for this?
Nissan Ariya
Nissan AriyaTBDElectric
