Hey guys, how do you avoid the small battery draining and getting error codes when tinting? Should I keep the car running or turned off? I noticed that the car doors are open during the tinting process.
Hi everyone, does anyone experience a strong odor in their Trumpchi cars after being exposed to high temperatures during the day? My GS7 has a particularly strong smell after being in the sun, even though I've used activated charcoal bags and anti-formaldehyde sprays. It’s so bad that it makes me feel dizzy and I can't keep my eyes open.
Hey car enthusiasts, I'm having some brake issues with my 2010 Volvo S80L. The brakes work fine when moving forward, but there's a chance of brake failure during short-distance reversing. A few days ago, when I changed the brake fluid, it was noticeably slow to drain out before adding the new fluid. Could it be that the brake fluid line is clogged? The brake pads are still quite thick, so I can basically rule them out. Any advice from the experts? 😬😬😬
I have a 2017 1.4T with all-wheel drive, driven over 60,000 kilometers in 5 years. When I accelerate to 60-80 km/h, there's a severe jerking, and it's slightly noticeable around 110 km/h too. I've changed the spark plugs and transmission fluid, and checked the engine mounts, but it hasn't helped. No error codes are showing up. Anyone else experiencing this issue? It's really frustrating to drive like this. I've been to several repair shops, even the dealership, and they suggested taking apart the transmission for inspection. 😖😖
4I have a 2014 Haima S5 manual transmission, and it's not running smoothly. During acceleration, it feels jerky and there's a noticeable lag when shifting gears. What's causing this issue? Can any experienced drivers or mechanics help me out? 🙏🙏🙏🙏🙏
5Hey fellow car enthusiasts, has anyone ever replaced the humidity sensor in a Grand Cherokee? If this sensor malfunctions, will there be an error code alert or any noticeable issues?
6Hey guys, my car is showing error code P048013, which is about fan 1 control circuit, general electrical fault, open circuit. Has anyone encountered this error code before? Thanks.
7Does anyone know if the light inside the trunk of a Haval H2 stays on continuously when opened? If I keep it open for half a day, will it drain the battery? Some car models have a feature where the trunk light turns off automatically to prevent battery drain.
8Hi everyone, when I'm accelerating with my FJ and shifting gears, I notice that the shift from 4th to 5th gear feels more pronounced and abrupt. Is this normal? There are no error codes. It's not noticeable during normal driving, but if I deliberately pay attention to each gear shift, I can feel a slight jolt from 4th to 5th. To notice this, I have to keep the throttle steady without releasing or pressing it more. During the 4th to 5th shift, there's a noticeable abrupt feeling. However, if I ease off the throttle during the 4th to 5th shift, there's no issue at all. Any thoughts or suggestions are welcome. Thanks!
9French car enthusiasts, I need your help. My 2.0 engine is making a strange noise. When I accelerate gently, there's no issue, but when I accelerate sharply, there's a "da-da-da" noise at around 2000 RPM. After a few seconds, when the speed picks up, it goes away. There's no noise above 3000 RPM, only during sharp acceleration. I bought it second-hand and didn't notice this sound before. If it's not a big deal, I'll just keep driving it for now. [Yeah][Cute][Cover face]
10Hey guys, how do you avoid the small battery draining and getting error codes when tinting? Should I keep the car running or turned off? I noticed that the car doors are open during the tinting process.
