Has anyone with the Ariya tried the single pedal mode with economy? Have you noticed that sometimes when you start, there's no response when you press down, and it takes a few seconds before the power kicks in?
My car has a weird problem. Sometimes it takes two tries to start. What could be the issue?
Hey folks, my manual Legacy feels powerless under 2000 RPM. Even when I step on the gas pedal hard, there's no response. What's going on?
There's a rattling noise like a loose plastic shell when accelerating while driving, but it's not there when revving in neutral. The noise also disappears when you press the accelerator pedal down hard after accelerating.
4When stuck in traffic, frequently braking and accelerating might lead to no response from the gas pedal. You'll need to idle forward a bit before the accelerator responds, or you can restart the engine to temporarily fix the issue.
5When the 2006 Legacy is in drive and you press the brake, there's a "doo doo" noise from the chassis, and the steering wheel and brake pedal vibrate. Sometimes it's mild, sometimes strong, and sometimes there's no issue at all. Could it be because the brake silencer pads weren't installed properly?
6Geely sometimes has no response when starting, but the dashboard and electrical components are powered. It happens occasionally. Is there a solution?
7What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
8Has anyone with the Ariya tried the single pedal mode with economy? Have you noticed that sometimes when you start, there's no response when you press down, and it takes a few seconds before the power kicks in?
9Why does my 2021 manual Santana sometimes have no response when I try to start it, requiring several attempts to ignite?
10Fellow car enthusiasts, have you ever experienced the brake pedal bouncing back a few times when you press it down?
