Can this be equipped with an air pump for tire repair?
Can this be equipped with an optional roof rack?
Can this car be equipped with a leg rest?
4Can the Ranzhi be equipped with a tire pressure monitoring system?
5The air conditioning internal circulation of the 2016 Hongqi H7 with the chrysanthemum logo is broken. How can it be repaired? Is it that one of the shafts of the air conditioning flap is broken? Do I have to replace the entire air conditioning assembly?
6Can this car be equipped with a power tailgate?
7Can a Jetta be equipped with a rearview camera?
8For the Prado 120, when choosing a rear lock, should you go for an electric lock or an air lock? If you choose an air lock, you will also need to buy an air pump, right?
9How do I reset the tire pressure after a repair? It still shows low pressure on the right rear tire.
10Do you need a wheel alignment after fixing a tire? My car shakes at speeds over 100 after a tire repair. What's going on? Can anyone help?
