avatar-image
علي همام
Feb 23
When starting a cold car, the RPM goes up to 2000 and then drops to 1500 but doesn't go any lower. The high idle speed is causing high fuel consumption, 20 liters for 300 kilometers! The idle speed is too high, and so is the fuel consumption. Can any experts provide a solution? 🙏
Comments( 7 )
خالد خديجة
خالد خديجة2024-07-16 00:23
Are you automatic or manual transmission, and how's the fuel economy after you changed the thermostat? [I want some peace]
حسين هادي
حسين هادي2024-04-20 13:30
My EGR is normally 1400, not sure why.
أحمد إدريسي
أحمد إدريسي2024-04-17 10:00
Replace the thermostat.
علي همام
علي همام2024-03-04 07:33
After changing the thermostat, the RPM really reached 890! [Thumbs up][Thumbs up][Thumbs up][Thumbs up]
حسين سيف
حسين سيف2024-02-28 19:05
The same issue, high RPM leads to high fuel consumption. Just replaced the thermostat today, idle is over 800. [Grin]
فهد حمد
فهد حمد2024-02-26 19:17
20 liters of fuel for 300 kilometers is still considered high consumption. What about my situation where 70 liters only covers 350 kilometers? / What is the city fuel consumption for the Volkswagen Teramont and the JAC Refine S7? /
عبد العزيز همام
عبد العزيز همام2024-02-23 22:20
Is the fuel consumption of the GA8 high?
Is the fuel consumption of the Land Cruiser really as high as they say? Does the five-speed transmission consume that much fuel?
The NC car weighs only 1175 kg, so theoretically, the fuel consumption should be quite friendly. Why is the fuel consumption relatively high? Could experts please provide an explanation? Thank you.
Is the fuel consumption high for the X70?
Are you asking if the fuel consumption of the Haval H6 is high? My car's fuel consumption is quite high right now. It takes about 20 liters per 100 km when starting and turning. I've already spent 700 yuan on fuel in less than a month. [Crying]
Is the fuel consumption of Jietu high?
When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
Hey everyone, what’s the fuel consumption of your Alto automatic? I feel mine is too high, 24.5 liters only covers about 300 km. The light came on at 287 km. Also, my idle speed when starting cold is around 1500, but it goes back to 1100 once the engine warms up. Is this normal for fuel consumption and idle speed?
The Volvo C30 2.0D has a normal idle speed of 850±20 RPM when in gear, but the idle speed is high at 950±20 RPM when in neutral. What's going on?
