When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
Whose car idles at 1000 RPM when warming up, and has anyone fixed it?
T8 idling at 1000 RPM, what's going on?
Why is my S40 idling at 1000 RPM, and how can I bring it down?
4Has anyone experienced idle running at 1000 RPM when the temperature is 35 degrees, and then it returns to normal at 800 RPM when the temperature is 26 degrees? What's going on? Please help.
5With a monthly salary of 2000, how long will it take to buy this car?
6Is anyone familiar with solving the issue of idle speed occasionally rising to 2000 RPM and then dropping back down on a stock MG HS? It's particularly noticeable at low speeds.
7When starting a cold car, the RPM goes up to 2000 and then drops to 1500 but doesn't go any lower. The high idle speed is causing high fuel consumption, 20 liters for 300 kilometers! The idle speed is too high, and so is the fuel consumption. Can any experts provide a solution? 🙏
8When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
9Why is the idle speed around 600 to 700 RPM?
10It's normal for the idle speed to fluctuate when you turn on the air conditioning in a 2013 1.6 manual fashion model. Sometimes the RPM might go up to around 900 or almost 1000, and other times it might be around 800. If you restart the engine and the RPM goes back to around 800, it's usually not a cause for concern.
