The new Suzuki Alto stalls when the air conditioning is turned on while idling in the summer.
The hand keeps blocking the Alto when reversing, it often stalls.
The Kia Sportage automatic stalled while adjusting the air conditioning in D gear at idle. It restarted successfully and has only happened once, otherwise everything is normal.
Why isn't the air conditioning in my Alto cooling?
4Which car's air filter is compatible with the Suzuki Alto's air filter?
5Does anyone else experience this issue with the Hongqi H7 1.8T? In the summer, when stuck in traffic, turning on the air conditioning for a few minutes causes the engine to show high temperature.
6Does your Santana's engine shake when you turn on the air conditioning for cold air?
7When I use the air conditioning for a longer time in the summer of 2019, the cold air stops blowing inside the car. Does anyone know why?
8Why does the air conditioning keep turning on and off at idle in first gear?
9Where is the air conditioning inspection hole located on the Changan Suzuki Alto?
10The new Suzuki Alto stalls when the air conditioning is turned on while idling in the summer.
