عبدالله قادر
2024-02-02 21:26
The hand keeps blocking the Alto when reversing, it often stalls.
Comments( 6 )
عبد العزيز هلال
عبد العزيز هلال2024-04-25 15:01
Step on the gas! Are you saving the gas pedal as a collector's item? [I want to be alone]
أسماء أحمد
أسماء أحمد2024-02-12 09:47
Give it a bit more throttle; with a smaller engine displacement, the power will definitely be a bit lacking.
حسين فادي
حسين فادي2024-02-05 00:08
Mine is like that too.
سعود هاشم
سعود هاشم2024-02-04 19:53
My car idles fine when reversing straight, but it stalls if I turn the wheel fully without adding gas.
عبد العزيز همام
عبد العزيز همام2024-02-04 09:06
The clutch might be broken.
عبدالرحمن أكرم
عبدالرحمن أكرم2024-02-02 23:17
Could it be a problem with the transmission?
The spare tire compartment always has water in it, what should I do? Is it because the drainage hole is blocked or is it an issue with the wiring of the installed reverse camera?
Is there a situation where it shifts to neutral by itself when reversing in reverse gear?
When I put my Smart Forfour into reverse, why does the rear wiper keep running? I checked the wiper lever and it's definitely turned off. Why does it keep wiping when in reverse? Does anyone know what the issue might be?
I have a 2012 automatic, and it often shifts to neutral when reversing, but there's no issue with driving forward. Has anyone encountered this problem? What could be the issue?
What could be the reason that there seems to be something blocking the brake pedal when I press the brake on a 207?
Does your Alto automatically return to the center when you turn the steering wheel?
Jeep Liberty, 2012 model with over 170,000 km. It often stalls, especially when reversing with the AC on. When waiting at a red light with the brakes fully pressed and the AC on, it occasionally stalls too. I can't read any error codes. Does anyone know what might be the issue? Could it be a compression problem?
The new Suzuki Alto stalls when the air conditioning is turned on while idling in the summer.
In the morning, when starting the vehicle and driving at low speeds, it occasionally stalls. I've already cleaned the throttle and injectors, but it still stalls sometimes. If the speed picks up, it doesn't stall. What could be the reason? 🤦‍♂️
