عبدالله محمود
2023-03-24 10:50
Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
عبدالله محمود
عبدالله محمود2024-05-14 20:13
The shock absorber was broken, and replacing it solved the problem.
عبد العزيز فيصل
عبد العزيز فيصل2023-03-25 18:42
Replacing the lower control arm fixed it.
فهد أمينة
فهد أمينة2023-03-25 07:23
First, check if the screws above are loose.
نايف رومي
نايف رومي2023-03-24 14:24
If it's making noise, just replace it. I changed a pair when only one was noisy.
Has anyone experienced a rattling noise from the front of an '08 Mazda 5 when driving on bumpy roads? I've just replaced the front shock absorber assembly, lower control arm, tie rod end, sway bar link, and stabilizer bar bushing, but the noise persists. Any ideas?
When driving over slightly rough roads, there's a clanking noise from under the front wheels, like metal hitting metal. Has anyone else experienced this?
Is there a clunking noise from the front left when driving on bumpy roads? Has anyone experienced this issue?
Has anyone here ever changed the front shock absorber top mount on an Ertiga by themselves? Is it possible to replace the front shock absorber top mount without removing the shock absorber itself? How do you get the top mount off? Any guidance would be appreciated. [Embarrassed face]…
Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
How much does it cost to replace the front right shock absorber on a 2019 GS5? Should I replace just one or both? 😢
2018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
I have a 2016 automatic model, and when driving on good roads, I hear a clear "clanging" sound from the right front tire area. Could this indicate a problem with the shock absorber? I just bought this second-hand car, looking for advice.
