How can I fix the issue of the engine noise being very loud when starting the Alto 1.0 when it's cold? The sound normalizes once the water temperature reaches 20 degrees.
I want to ask, I bought a new car and have driven 2000 kilometers, the car is overheating, and the water temperature gauge shows 90 degrees. How can I solve this issue?
Has anyone experienced idle running at 1000 RPM when the temperature is 35 degrees, and then it returns to normal at 800 RPM when the temperature is 26 degrees? What's going on? Please help.
Is it normal for the water temperature of a 2015 Peugeot 508 to be around 90 degrees? [crying][crying][crying]
4At 45,000 kilometers, there's no issue with a heavy throttle, and there's no problem with a light throttle either. But when I press the throttle slightly harder, the issue arises, especially noticeable at 2000 RPM. There's no such problem when the car is cold, but once the water temperature reaches two bars, it comes back. It's really frustrating. Any advice? 🙏🙏🙏
5What could be the reason for not being able to shift gears when the car is cold?
6How can I fix the issue of the engine noise being very loud when starting the Alto 1.0 when it's cold? The sound normalizes once the water temperature reaches 20 degrees.
7Hey guys, my 2014 Alto's coolant temperature doesn't go above 80 degrees. Is this normal? Should I replace the thermostat? Which one is better, the original or from Tenpu?
8When I start my 2021 Outlander, there's a popping sound in the engine bay during cold starts, but it goes away once the temperature rises. Has anyone else experienced this?
9Is it normal for a 2014 Peugeot 2008 1.6 automatic to have the engine temperature rise very slowly, taking over ten minutes to reach 70 degrees? Could it be that the engine oil is too thick?
10Is it normal for the fan to frequently turn on, with a particularly loud noise, and then stop after a while, even when the water temperature is normal? Has anyone experienced this? It also happens when idling, where it turns on once every few minutes.
