حسن زيد
2024-03-07 21:59
Hi everyone, I have a 2013 Suzuki Alto automatic. When I start and just slightly press the accelerator, the RPM quickly goes up to 2000. Even when the speed reaches 60, the RPM stays around 2000. What's going on here?
عمر خلدون
عمر خلدون2024-03-11 22:05
Normal warm-up at 2000 RPM for 70 seconds.
عمر شعبان
عمر شعبان2024-03-08 21:41
That's normal. It's like that for everyone.
When driving a manual transmission car, if you hear a rubbing noise from the engine slightly above 2000 RPM, but it disappears above 2300 RPM, what could be the reason?
At 45,000 kilometers, there's no issue with a heavy throttle, and there's no problem with a light throttle either. But when I press the throttle slightly harder, the issue arises, especially noticeable at 2000 RPM. There's no such problem when the car is cold, but once the water temperature reaches two bars, it comes back. It's really frustrating. Any advice? 🙏🙏🙏
Does your engine also make a loud noise when the RPM reaches 2000? Especially when going uphill, all I can hear is the roar of the engine.
Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
The new Suzuki Alto stalls when the air conditioning is turned on while idling in the summer.
Hi everyone, can someone help me out? Today, I suddenly noticed a noticeable "da-da-da" sound from the engine when it goes above 2000 RPM. What could be the issue?
Why does the remaining range drop so quickly when idling with the AC on? Stayed for two hours and the range dropped by 60 kilometers [crying]. Didn't even drive the car, is the fuel consumption really that high? Does everyone experience this?
