avatar-image
سلمان سعود
Mar 19
Hey guys, my 2014 Alto's coolant temperature doesn't go above 80 degrees. Is this normal? Should I replace the thermostat? Which one is better, the original or from Tenpu?
سعود بشر
سعود بشر2024-04-17 11:39
You can buy Tianbo online and replace it yourself.
أحمد إدريسي
أحمد إدريسي2024-04-17 09:59
The thermostat for the new Alto is easy to install. Just buy a Tianbo one for 15 yuan! Installation is simple, and the thermostat comes with its own gasket, so you don't need to use sealant!
عبدالله مكرم
عبدالله مكرم2024-03-19 21:41
That's fine, change the coolant as well.
Is it normal for the fan of a 2015 Sharan with 150,000 km to keep running at high speed after turning off the engine and removing the key, especially after driving 30 km with the AC on? The current outside temperature is 39 degrees. Looking for advice from fellow car enthusiasts.
Has anyone experienced idle running at 1000 RPM when the temperature is 35 degrees, and then it returns to normal at 800 RPM when the temperature is 26 degrees? What's going on? Please help.
Is it normal for the water temperature of a 2015 Peugeot 508 to be around 90 degrees? [crying][crying][crying]
Fellow car enthusiasts, have you experienced slow shifting between the 6th and 7th gears with your 7-speed dry dual-clutch transmission? Mine doesn't shift to 7th gear even at 80 km/h and waits until it reaches 85 km/h. Is this normal?
Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
Does anyone know why the water temperature gauge on the 2020 Jetour X70 with 1.5T engine sometimes shows six bars and sometimes five bars? I've already replaced the thermostat, but it still doesn't work.
How can I fix the issue of the engine noise being very loud when starting the Alto 1.0 when it's cold? The sound normalizes once the water temperature reaches 20 degrees.
I have a used Suzuki SX4 AWD with 130,000 kilometers. In extreme cold weather (minus 40), it drives very steadily. However, when the temperature rises to around 5 degrees above zero, it feels a bit floaty and unstable at speeds of 80 to 100 km/h. Can fellow car enthusiasts offer some advice?
Is it normal for a 2014 Peugeot 2008 1.6 automatic to have the engine temperature rise very slowly, taking over ten minutes to reach 70 degrees? Could it be that the engine oil is too thick?
