Hey Alto friends! After I connected the reverse radar wires myself, the car started twice without any issues. But after I arranged the wires, it won't start anymore! Does anyone know what might be causing this?
How to deal with the issue of the reverse camera not responding on a 2005 Nissan Bluebird after starting, and where to connect the wiring?
The gear lever on this company car is problematic. After shifting to reverse, the detent stays in the engaged position even when you return it to neutral. You have to push it down to disengage. I didn't pay attention today, and when coasting downhill while pressing the clutch, I directly shifted to first gear without pushing the detent down. As a result, the car stalled and now it won't start at all.
Today, when I started the car, there was a "da-da-da-da" sound. After turning the engine off and starting it again, the sound was gone. This has happened twice. Not sure what the cause is.
4Hey Alto friends! After I connected the reverse radar wires myself, the car started twice without any issues. But after I arranged the wires, it won't start anymore! Does anyone know what might be causing this?
5How's your car battery? Mine won't start after sitting for three days. Any advice?
6Has anyone replaced the key battery before? After I replaced the car key battery myself, I can remotely lock and unlock the doors without any issues, but the car won't start when I insert the key. The anti-theft system isn't connecting. Does anyone know how to solve this?
7The screen was working fine until the afternoon, but after being exposed to the sun all day, it started to malfunction. What can I do to fix the screen issue without replacing the car stereo? I'm concerned about the repair cost being too high. Is there a way to fix it myself?
8After starting the 2019 Taurus, the steering wheel won't turn in place, even when reversing. It only turns when reversing while moving. However, it works fine when driving forward. Has anyone experienced this issue?
9If you leave the key in the ignition for too long without starting the car, it won't start. If the key is in the ignition for more than half a minute without turning the engine on, the key becomes stuck and you have to turn off the power and try starting the car again.
10Hi friends, what is the idle RPM for your GAC Emkoo after starting the engine?
