Yuexiang, oh Yuexiang, the more I think, the more I want it. Didn't they say it was discontinued? How come it's still selling a few thousand units each month? Where exactly can you buy it?
Is this car going to be discontinued??? 🤔😭😭😭 I ordered this car on September 25th last month, and just got a call two days ago saying they can't fulfill the order??? What's going on?
4I have high hopes for Chery cars, but buying one can be disappointing. First, many car companies now offer lifetime free maintenance, but Chery does not. Second, when it comes to window tinting, the dealership tells you that it's outsourced, and you have to drive the car there yourself. Once you arrive, you find out the tint is transparent, which is basically like having no tint at all. If you want better quality tint, you have to pay a few thousand more out of pocket, and the sunroof isn't included either. Other car companies usually provide better quality tint for free. Third, when picking up the car, they inform you about insurance and say that to have "no damage" coverage, you need to spend several thousand more. I just want to say, Chery, can you not make potential buyers of Chery cars feel disappointed?
5I have a 2018 Outlander 2.4 AWD. Last month, the right front wheel got hit, and I had to replace the shock absorber, half shaft, and steering rack. 😒😒😒 Now, when I'm driving at around 110 km/h, the steering wheel vibrates in my hands. It's not exactly a shake, but more of a tingling feeling. The car doesn't drift or vibrate, just the steering wheel. If I grip the wheel tightly, it feels a bit better. There's no issue when driving below 100 km/h. I've done wheel alignment, and the data is spot on. I've also done wheel balancing and swapped the front and rear tires. I've even replaced the front bearings, but there's no change. The repair shop said the next step would be to start replacing parts one by one, but that would be too costly. Does anyone know what the problem might be? I'd be willing to offer a small reward for a solution. 😏😏😏
6Is there anyone else waiting for the range extender version? This car really hits the spot for me. Just look at the Denza D9, selling around 10,000 units a month, with only about 500 being pure electric. You can see how few people can accept a pure electric MPV. Zeekr, please hurry up and release the range extender version. Also, offer a pure electric option so consumers have more choices. Sales will definitely go up.
7Didn't they say this car was discontinued? Why are there still a few hundred sales every month, just going steady? Aren't people worried about after-sales issues?
