What size socket do I need for the bolts on the 2009 Yuexiang wheel? Is it 19mm? Thanks everyone. 🙏
Hello everyone, I want to ask what size are the loudspeakers in the Previa ACR50?
Hello everyone, can the lighting height of the 2021 LTD version be adjusted? Also, how do I adjust the night mode on the central control screen? Thanks 🙏
Is the socket for removing the anti-theft wheel bolts of the 2018 Sharan number 533?
4Do I need to report if I change the roof of my Yuexiang from blue to white?
5What size socket do I need for the bolts on the 2009 Yuexiang wheel? Is it 19mm? Thanks everyone. 🙏
6Hey guys, isn't the 2019 Changan Yuexiang's wheel 14 inches? The tires are 175/65/R14. I'm thinking about changing the tires. What's the maximum size I can switch to? Thanks.
7What brand of tires should I use for the front wheels of a 453? The size 165/65R15 is indeed rare. Thanks.
8Can the 2.0T Rui Shang be fitted with 20-inch wheels? Has anyone done it before? Please reply, thank you 🙏🙏🙏
9I'm torn. What are the limitations of the 8-seater version 130 on the highway? Can someone knowledgeable help me out? Thanks, everyone! 🙏🙏🙏
10My Taurus just hit 30,000 kilometers. What maintenance does it need? Do I need to change the spark plugs and brake fluid? Thanks, everyone!
