What should I do about the gear shifting impact in the Yuexiang when it's fine when cold but jerks when hot?
The Kia Sportage has a jerking sensation when shifting gears.
Why does the Changan Yuexiang jerk when starting in D gear?
Is the 2022 GA6 experiencing jerking when shifting from second to third gear and also when accelerating at low speeds in third gear a common issue for this model?
4What could be the reason for not being able to shift gears when the car is cold?
5Has anyone experienced gear shift jerking after just replacing the spark plugs and cleaning the throttle? It was fine for two or three days, but then the jerking returned.
6What should I do about the gear shifting impact in the Yuexiang when it's fine when cold but jerks when hot?
7Does your Jetta automatic also have a noticeable jerk when shifting gears?
8Hey fellow car enthusiasts, do all fuel-powered cars experience jerking when shifting gears? Mine does when shifting from 1st to 2nd. In this situation, will the dealership replace the electro-hydraulic module?
9I recently got a CX-5 less than a month ago, and I noticed that when starting the car cold and shifting to D gear, there's a noticeable "jerking" sensation as the car moves forward. After driving for a while and the car warms up, when switching between N and D gear, the jerking sensation is still there but much less noticeable. Is this normal?
10Why is there an impact when shifting from R to D gear?
