What causes the steering wheel not to return to center automatically?
What could cause the steering to be heavy on a 2015 Haima S5 automatic?
Hey fellow car enthusiasts, with the 2023 GV80, has anyone experienced the steering wheel not returning to center on its own, needing manual turning back?
4Hi everyone, I have a 2017 Murano and noticed that the steering wheel doesn't return to the center after turning. Is this normal for you guys? I just discovered this issue.
5Does your Alto automatically return to the center when you turn the steering wheel?
6Hi everyone, just wondering if the steering wheel of the Skoda Rapid doesn't return automatically when driving at low speeds?
7I have a question for the owner of a BYD Song Plus fuel version. Does your car's steering wheel automatically return to the center after you turn it all the way while stationary and then start driving?
8Does your car's steering wheel automatically return to center when you make slight adjustments at high speeds? When you make minor adjustments with one hand, do you feel a lot of resistance?
9What causes the steering wheel to make a noise when turning the shaft?
10Why is the steering on my 2018 X-Trail heavy and not returning to center automatically?
