The tire pressure warning on the third-generation Yuexiang keeps appearing. After driving for a while, it disappears. What's going on??
How to reset the tire pressure on an F150 after patching the tire? [what][what]
After removing the rear hanger, the tire pressure light keeps staying on. Is there a good way to fix this?
Is the steering wheel of the third-generation Changan Yuexiang a bit heavy? Is yours like this too? Can it be adjusted?
4Where is the gasoline filter located in the third generation Yuexiang?
5The tire pressure warning on the third-generation Yuexiang keeps appearing. After driving for a while, it disappears. What's going on??
6The tire pressure is fine, but the tire pressure light came on this time it snowed. What's going on?
7How do I reset the tire pressure after a repair? It still shows low pressure on the right rear tire.
8I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
9Have you ever experienced the second generation MG6 occasionally requiring a second attempt to start? Are there any warning lights appearing? What is the situation?
10Where do you all go for maintenance on the 2020 third-generation MG6?
