عمر أسماء
2024-01-17 21:27
The air conditioning in my 2019 model Yueshang only blows air towards the front windshield, while there's no air coming from the center console or side vents. Does anyone know what might be causing this issue, and is it complicated to repair?
The rear air conditioning vents are not blowing cold air?
Does anyone know if the center console screen frame panel of the 2016 model is the same as the 2012 model? I only found the panel for the 2012 model, the one with the air vents.
I've got a 2014 Grand Cherokee, and lately when I turn on the heater, the driver's side vent blows cold air while the passenger side vent blows warm air. Does anyone know what might be causing this?
Is it worth buying a 2011 automatic high-end 1.5 with 110,000 km for 18,000? The front windshield has been replaced, and the rear air vent can't blow warm air. I didn't look into other details. I took a short drive and didn't notice anything unusual.
How to remove the air conditioning vent louvers?
When I turn on the AC in my 2019 Taurus, the rear vents blow hot air. What could be the reason for this? Can anyone help explain?
Is the warm air blowing on the windshield of your LC120 also weak?
Changan Changan Alsvin
Changan AlsvinAED 36,750 ~ 47,035Gasoline & Petrol
