The 2019 Yuexiang has a strange noise from the belt area when starting in sub-zero winter temperatures, but it goes away after a few minutes. After inspection, no issues were found. What's going on?
When I stop my KIA Soluto, turn off the engine, and shut everything down, after about a minute, there's a strange noise. It sounds like a locking noise, but it's not exactly that. Does anyone else experience this with their automatic transmission? Does anyone know the reason? Please let me know.
I bought a 2023 Lavida Star Edition in July. Last week, I accidentally noticed a strange noise around the right rear tire about six minutes after turning off the engine. Friends, do you know what might be causing this?
Hello fellow car enthusiasts, I have a 2009 manual model. In the past two or three years, I've noticed that the braking power of the rear wheels has been continuously decreasing. I've consulted several repair shops and had it inspected, but no problems were found. I'd like to ask if anyone has solutions for this issue.
4My car was involved in an accident in 2018, affecting the front bumper and radiator area. It was repaired at the 4S shop. For the past four years, there were no issues during the vehicle inspections. However, this year, the inspection technician said that the vehicle identification number in the engine compartment had been altered. What's going on with this?
5The 2019 Yuexiang has a strange noise from the belt area when starting in sub-zero winter temperatures, but it goes away after a few minutes. After inspection, no issues were found. What's going on?
6The sound of rustling near the throttle belt on a 10-year-old Alto could be due to several reasons. It might be caused by a worn-out or loose belt, debris stuck in the belt area, or possibly an issue with the belt tensioner. It would be best to have it inspected by a professional to determine the exact cause.
7Jetur X70, 2020 model. I started having a coolant leak, and when pressure was applied, the leak point was found. The four-way valve was replaced, and the heating pipe and water inlet pipe were tightened. It was also discovered that the water pump was leaking, and eventually, everything was replaced. However, after refilling the coolant, the mechanic found that the engine temperature was high, but it drops as soon as the heater is turned on. They spent half a day but couldn't find the problem, and the car not being fixed has caused a lot of issues. Have you encountered this before? How did you handle it?
8The engine warning light came on after driving over 10,000 kilometers, right when it was time for maintenance. The service station checked and found the gas cap wasn't properly sealed, and they reset the computer. However, the yellow light came back on in less than half a month. The service station is too far away, and I don't have time to go there. Does anyone know what the problem might be? Any help would be appreciated.
9I bought the 2019 Bestune T99 in September 2020. Since it was my first car purchase, I lacked experience and fell into many traps. Besides having many minor issues, I later discovered several parts were damaged. The tires were previously used, which immediately made me suspect that this car was probably a test drive vehicle. And I was right. A few days ago, I went to replace the turn signal lights and found that the wiring inside had been reconnected, and the connections were poorly done. Moreover, the production dates of the left and right turn signals were almost a year apart. (Cars from the factory have uniform dates.) After all these years, it's impossible to explain this to the dealership now! I hope everyone pays attention to details when buying a car to avoid being deceived.
10Hey fellow car enthusiasts, I've got a 2023 2.0T RuiShang and there's a strange noise when starting up. After starting, there's a "boom" sound after a little while. It happens every time, and it seems to be coming from near the driver's side door, around the left front wheel area. I've taken it to the dealership, but they couldn't find the cause. Has anyone else experienced this?
