نايف ظافر
2024-02-18 01:35
Has anyone with a 2019 Changan Yuexiang 1.5L with a dual-clutch 5-speed transmission, which has now run 100,000 kilometers, experienced slow shifting and a hissing sound when shifting? How did you solve this issue?
Is it true that all used 2019 Changan Yuexiang automatic models are from Liandongyun? How can you tell if the catalytic converter has been tampered with?
I want to ask about my 2019 Changan Yuexiang automatic. When I start the car cold and shift gears, it takes about 2000 RPM to change gears, like the clutch is slipping. Once the engine warms up, the shifting is normal. Do other car owners experience the same issue?
I'm considering buying a used Jeep Renegade. Today, I saw a 2017 model with a 1.4 automatic at a dealer. I've heard that dry dual-clutch transmissions often have issues. What do other car enthusiasts think? Also, the car has a noticeable tapping noise at idle. Is this a common issue with this model?
MG3 2013 model 1.3L manual. Around July last year, the clutch wouldn't spring back, so I replaced the clutch kit. Recently, with the hot weather, the issue has reappeared several times. When the car heats up, the clutch rebound is particularly slow, and after a while, it won't rebound at all. If I park by the roadside for a bit, it gets slightly better. There's also a strange noise when pressing the clutch.
For manual transmission, has anyone experienced the issue of the clutch not returning? How did you solve it? Should I replace the slave cylinder or the spring?
Does anyone know if the Changan Yuexiang from LinkTour has the auto door lock feature? I've tried many setup videos but haven't succeeded. No matter the speed, the doors won't lock automatically. Help! Help! Help!!!
Fellow car enthusiasts, have you experienced slow shifting between the 6th and 7th gears with your 7-speed dry dual-clutch transmission? Mine doesn't shift to 7th gear even at 80 km/h and waits until it reaches 85 km/h. Is this normal?
Is the clutch adjustable on the manual Changan Yuexiang?
What could be the issue with the 2019 JETOUR X70 having difficulty shifting gears? The clutch master cylinder and transmission have already been replaced, and the issue has somewhat improved. However, sometimes it's still hard to engage first gear.
Changan Changan Alsvin
Changan AlsvinAED 36,750 ~ 47,035Gasoline & Petrol
