For the 2009 Yuxiang, the driver's door often won't open. I have to lower the window and use the mechanical key from the outside several times. The other three doors are fine. Can someone tell me if this is a common issue with the old Yuxiang? [Facepalm]
There could be several reasons why your 2.9T6 steering feels particularly heavy. Common causes might include low power steering fluid, issues with the power steering pump, or alignment problems. It's also possible that the tires are underinflated or there's an issue with the steering linkage. It would be best to have a professional mechanic inspect your vehicle to diagnose the exact cause.
Has anyone experienced the driver's door window on the Scirocco only lowering a little bit when opening the door? What could be causing this issue?
4Is the severe shaking of the driver's side window when lowered a common issue with the Lingfang?
5During the rainy season, typically from April to August, the car doors cannot be opened from inside or outside, while they function normally at other times. Could it be that the lock mechanism is affected by moisture on rainy days? What might be the issue here? Experts, please help! Thank you!
6After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
7Four years, 40,000 km, 1.5T F56. There's noticeable shaking and noise at idle. Is this common for everyone? I bought it second-hand, so I'm not sure how it was when new. Also, when driving on rough roads, there's noise from the left and right side windows. When the windows are down, there's no noise. I suspect it might be the frameless doors causing the glass to rub against the body. Does anyone else experience this?
8I have high hopes for Chery cars, but buying one can be disappointing. First, many car companies now offer lifetime free maintenance, but Chery does not. Second, when it comes to window tinting, the dealership tells you that it's outsourced, and you have to drive the car there yourself. Once you arrive, you find out the tint is transparent, which is basically like having no tint at all. If you want better quality tint, you have to pay a few thousand more out of pocket, and the sunroof isn't included either. Other car companies usually provide better quality tint for free. Third, when picking up the car, they inform you about insurance and say that to have "no damage" coverage, you need to spend several thousand more. I just want to say, Chery, can you not make potential buyers of Chery cars feel disappointed?
9When the window glass in the Outlander's cabin is lowered and the door is closed with a bang, what's going on?
10Hi everyone, can someone tell me how to set up the automatic door lock for a 2010 Volvo S40? Thanks!
