Engine loses RPMs and the vehicle shakes when starting.
Does the gear stick shake when starting a manual transmission car?
What causes the Yaris to shake when starting?
4What could be the problem if the engine shakes violently upon starting and requires turning off and restarting?
52017 model 1.4T, now the temperature is around 3°C. When I start the car, the RPM is at 1200, and when I start driving with a cold engine, the RPM goes above 3000 before it shifts gears, and it feels shaky. Do you guys experience this too?
6When driving a 2021 model and releasing the accelerator, the vehicle shakes. Does anyone know the reason for this?
7My car is a 2013-2015 model Jetta with a 1.6-liter engine. Sometimes when starting the car, the engine revs low, leading to failure to start properly. Normally, when a car starts, the engine speed should be over a thousand RPM before settling down to idle speed. However, sometimes my car starts at 800 RPM, feeling like it's about to stall. The battery is newly replaced, and tests show no issues with it.
8What could cause a car to shake when starting cold?
9Why does the Outlander have high RPMs when starting in the morning?
10Hi friends, what is the idle RPM for your GAC Emkoo after starting the engine?
