Can the 1.5L Comfort model be equipped with cruise control? Does the original car system include a cruise control module?
Can the 2020 2.0 Elite Edition Mitsubishi ASX be equipped with cruise control and lane keeping assist?
Can I add cruise control to the 2018 2.0 Leading model?
Can the premium version, which only has cruise control, be upgraded to adaptive cruise control?
4Does anyone know how to upgrade the central control of the 2017 model to include CarPlay?
5Can the 2020 ASX be modified to include cruise control?
6Does this car have cruise control?
7The difference between canceling cruise control and turning off cruise control in a Patrol is essentially about how the system is deactivated. Canceling cruise control is a temporary deactivation, allowing you to resume the set speed later, while turning off cruise control completely deactivates the system until you set it up again.
8The difference between the "Cancel Cruise" and "Turn Off Cruise" buttons on the steering wheel of a Patrol is as follows: - **Cancel Cruise**: This button temporarily deactivates the cruise control while keeping the set speed in memory. You can resume the cruise control to the previously set speed later without having to set it again. - **Turn Off Cruise**: This button completely deactivates the cruise control system and clears the set speed from memory. To use cruise control again, you would need to set the speed anew.
9Does the 2022 model of The one come with cruise control installed?
10Does the 2023 Macan 2.0T come with standard cruise control or adaptive cruise control? Can someone explain this?
