عيسى حسين
2023-06-22 10:57
2010 Changan Yuexiang, experiencing body vibration at low speed and low RPMs. The symptom disappears at higher speeds. What could be the issue? Is it the valves or are the engine mounts worn out?
When the windows are closed and the music is off, I can hear a faint ticking noise while gently pressing the accelerator in park mode. It seems to come from the center console, like a small motor vibrating. When I press the accelerator hard, the sound disappears. I can also hear it occasionally when driving at low speeds or when releasing the accelerator. The noise is noticeable when starting the car cold, and it feels like a metal-on-metal vibration or collision underfoot. Interestingly, after driving for a while, the sound goes away. However, if the car is stopped for a while and then started again, the noise returns initially but disappears after driving for a bit.
When driving at low speeds and turning the steering wheel, the 2014 XV experiences significant body vibration and loud noise. However, this issue does not occur when the car is cold and has just started. I want to know what the reason could be? Does anyone else have the same situation?
Does anyone know if the Changan Yuexiang from LinkTour has the auto door lock feature? I've tried many setup videos but haven't succeeded. No matter the speed, the doors won't lock automatically. Help! Help! Help!!!
When starting, there's a noticeable vibration, but the higher the speed, the less the vibration. There's no vibration when coasting, but as soon as you accelerate, you feel it, especially at lower speeds. Why is that? There's no unusual noise. I've already replaced the left half axle, engine mounts, and recently changed the tires and ignition coils. The repair shop says it's an issue with the transmission and it needs repairs. Is that true? 😮‍💨
Has anyone with a 2019 Changan Yuexiang 1.5L with a dual-clutch 5-speed transmission, which has now run 100,000 kilometers, experienced slow shifting and a hissing sound when shifting? How did you solve this issue?
2010 Peugeot 307, automatic transmission. Why does it make a squeaking sound every time I accelerate at low speed and then suddenly release the accelerator?
Changan Yuexiang, ABS and anti-skid fault, diagnostic shows a left front wheel speed sensor fault. I replaced it, but the lights are still on, and the diagnostic still shows the left front wheel speed sensor fault. However, all the data streams are present. The fault can be cleared, but it comes back while driving. What should I do?
Changan Changan Alsvin
Changan AlsvinAED 36,750 ~ 47,035Gasoline & Petrol
