فهد هشام
2024-06-06 13:34
What are the original floor mats like in the 2024 Alphard? Why are the materials for the front and rear seats completely different, and why is there no logo on the rear floor mats?
Why did the Ousheng front suspension change from the original double wishbone to MacPherson suspension?
Is the ambient lighting in the 2024 Villa Pro only in the front row or in both the front and rear rows? Mine only has it in the front row.
What's causing water under the passenger seat and rear floor mat of the Haima S5? Where is it leaking from? If anyone knows, please reply, thanks!
I only replaced the front two tires, not the rear ones, and they're from two different brands. The tread patterns are quite different, and the load capacity and speed ratings aren't the same. Is this okay? Is there any risk? Do I need to replace the rear tires as well?
Why did the designers decide to place the rear wheel arch on the rear door? The car's length has increased significantly, so why is the position of the rear wheel arch just a few centimeters different? This is a bit unusual.
Hi Lions, looking for recommendations for reliable floor mats. TPE material seems good. Any recommended sellers?
I ordered the 2024 X version in-stock car, and it shows Santorini Black. But I see the 2024 models are called Meteorite Black. Why are they different? Can anyone help explain my confusion? 😊
Is there a problem if the tire pressures are different? Front left 240, rear left 250, front right 240, and rear right 233. Is it okay to drive?
Originally, a single action would complete the task, but now the rear and front passenger windows require three or four actions to complete, and you also have to look at the indicator on the screen. What's the design philosophy here? Does more complexity equate to a more premium feel?
