Is there still an additional charge?
Is it convenient to install additional loudspeakers in the rear of the 2019 model?
Does the 2024 model of Vellfire require an additional premium?
Is there an additional charge of 2000 for pearl white?
4Is this car currently available in stock, and how much is the additional cost?
5Has anyone here used fuel additives? Do they work?
6Is there still an additional charge?
7I can't charge my electric Lavida, thought it was a grounding issue (there's a grounding wire left by the developer in the electrical box), so I connected it to the ground as well, using two 60cm grounding rods and a 50cm grounding angle iron, but it still sometimes charges and sometimes doesn't. Even the portable charger doesn't work. It's driving me crazy. When I took it to the 4S dealership, it charged fine. They updated the car's system, but it still won't charge at home. I tried two neighbors' charging stations, but it still won't charge. What's going on? Has anyone experienced something similar? It's been over 3 years and 50,000 km.
8Has anyone used fuel additives?
9Is there an additional luxury tax for options on the 25 Majesty extended version?
10Is it necessary to choose additional options for the G80, or is it not available as a base model?
