نايف جلال الدين
2024-03-07 13:39
How to deal with the sound from the accelerator pedal of the Alphard 40?
How to deal with water leakage from the rear spray nozzle of Jimny?
When the Prado 4.0 is between 40 to 50 mph, the steering wheel vibrates, and there's a humming sound.
I want to ask, how can I deal with the creaking sound from the rear seats of the T8?
How to choose between the new Alphard and the old LM?
When stuck in traffic, frequently braking and accelerating might lead to no response from the gas pedal. You'll need to idle forward a bit before the accelerator responds, or you can restart the engine to temporarily fix the issue.
1.4T T-Cross, there's a buzzing sound when accelerating above 60 km/h, but no sound when not accelerating. Looking for answers to the issue.
Hey drivers, anyone know why my car suddenly can't accelerate while driving? I press the gas pedal and nothing happens. 😩😩 Then, when I press the brake and then the gas pedal, it accelerates. What's going on? 😎
Changan CS95 accelerates at 40-50 mph with high RPM but lacks power. What could be the issue?
Today, while driving my 2020 automatic Chery Arrizo 5, I heard a squeaky noise from the accelerator pedal when I pressed it to accelerate. When I released the pedal, it didn't return to its original position and kept accelerating, which scared me, so I quickly braked and pulled over to turn off the engine. I then shifted to neutral and started the engine, which roared to over 4000 RPM. After turning it off, I manually adjusted the pedal, heard the squeak again, and then it started working normally. Occasionally, there's still a noise when pressing the accelerator, but the pedal returns to normal. Does anyone know what might be causing this issue or what might be broken?
Toyota Toyota Alphard
Toyota AlphardAED 220,000Hybrid
