عبدالله عمرو
2024-04-15 08:50
Hi, buddy! If you're trying to change the music in your Alphard and can't find where to plug in the USB, I totally get it. In the Toyota Alphard, the USB port is usually located in the center console or near the dashboard. Sometimes, it can be a bit hidden, so you might need to check around those areas carefully. Hope this helps!
The engine number for the 2008 2.5T Volvo C70 is typically located on the engine block. It's usually found on the passenger side of the engine, near where the engine and transmission meet. You might need a flashlight to see it clearly, as it can be a bit hidden. Make sure to check around the area thoroughly.
My 2019 Model 95, the USB port next to the cigarette lighter on the center console isn't working. It doesn't charge my phone, and when I plug in a USB drive, there's no response. What's going on?
There could be several reasons why the music USB drive isn't responding when plugged into the USB port of your car or other device: 1. **Compatibility Issues**: Some car USB ports or devices may have compatibility issues with certain USB drives or file formats. Ensure the music files are in a supported format like MP3. 2. **File System Format**: Check if the USB drive is formatted in a compatible file system, such as FAT32 or exFAT, which are commonly supported by car audio systems. 3. **USB Port Problem**: The USB port itself might be faulty. Try plugging the USB drive into a different port if available. 4. **USB Drive Issue**: Although it works on your computer, there might be an issue with the USB drive that affects its performance in other devices. Consider testing with another USB drive. 5. **Device Settings**: Check the settings of the device you're plugging the USB into. Some settings might need to be adjusted to read external USB storage. 6. **Power Supply**: Ensure that the device has enough power supply to read the USB drive, especially if it's an older model or if there are multiple devices connected. Try troubleshooting with these suggestions to identify the cause of the problem.
Toyota Toyota Alphard
Toyota AlphardAED 220,000Hybrid
