Why is my car's rear shock absorber leaking oil? Is this covered under warranty?
Is there anyone who has changed the rear shock absorbers because of abnormal noise and excessive stiffness?
Does anyone know where to buy rear shock absorbers?
Why does the car make a humming noise at 40 mph? The noise is very loud, and the shock absorbers have been replaced.
4Is the X95 water pump not covered under the extended warranty?
5Do any of you with the old 2012 model of Changan Yuexiang have issues with rear wheel shock absorber top corrosion and rust, leading to the shock absorber falling off? If you do, please type 1, thank you.
6Looking to purchase two rear shock absorbers, removed from a modified Vito.
7The 2021-2022 model with just over 52,000 kilometers on the engine is experiencing issues, but it is not covered under warranty.
8What exactly is covered under the lifetime warranty that the manufacturer claims for the Roewe RX5 MAX?
9Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
10Why is my car's rear shock absorber leaking oil? Is this covered under warranty?
