سعود حمد
2024-09-30 20:31
Why does my car suddenly feel heavy while driving? It always feels like the brakes are on, and it won't move unless I press the accelerator hard...
عبد العزيز أكبر
عبد العزيز أكبر2024-10-02 09:13
Did you switch to manual mode (M mode)?
عبد الرحمن سعود
عبد الرحمن سعود2024-10-02 07:39
When in the P gear and idle, it will automatically move.
What could be the reason for the 2019 car's accelerator feeling heavy and not responsive?
When the car is in D gear at idle, it feels weak (like an ant crawling), but when you press the accelerator, it becomes normal. In reverse gear, it doesn't move at all unless you press the accelerator. The car is a 2016 Haima S5.
Why does it sometimes feel like the brake and accelerator are hard when I start the car, and other times they're soft? It feels uncomfortable to drive when they're hard.
There's a rattling noise like a loose plastic shell when accelerating while driving, but it's not there when revving in neutral. The noise also disappears when you press the accelerator pedal down hard after accelerating.
My One suddenly won't move when I press the gas while in D gear today. It feels like something is dragging it. Any fellow car enthusiasts know or have encountered this situation before?
What could be the issue if the steering suddenly becomes heavy and hard to turn, even though there's enough fluid?
Is it normal for the brakes to apply themselves without pressing the accelerator while driving?
Hey drivers, anyone know why my car suddenly can't accelerate while driving? I press the gas pedal and nothing happens. 😩😩 Then, when I press the brake and then the gas pedal, it accelerates. What's going on? 😎
